Hi,
In Norway we have an operator called Sikringsradioen (Sikringsradioen: VHF-radioene med lengst rekkevidde og egen nødknapp) which operates a PMR network with base-stations in the VHF frequency range. The analog frequencies are well documented; http://frekvenser.no/Jaktradio.html (the channels with "Sikringsradio" in the "Navn" field).
The digital frequencies are however not documented. These channels are also only radio to radio frequencies without repeaters (at the moment). I have a radio with these frequencies programmed, but since the device is locked I'm unable to read what frequencies they are sending on. So I used an rtl-sdr with sdrsharp and sdrpp to figure out the frequencies it uses. This is done only by eyeballing the sdr interface and are not 100% accurate. Here's a screenshot:
And here's the list of frequencies I've made:
01: 143.4315
02: 143.4190
03: 138.9315
04: 138.9190
05: 143.5064
06: 143.4945
07: 139.0065
08: 138.9940
09: 143.2064
10: 143.1939
11: 138.7060
12: 138.6940
I've tested that they actually work with an other programmable radio (with group call id 100000, color 1 and TS 1), but as I mentioned these frequencies are not perfect which might have an effect when starting to use these over longer distances.
How can I figure out the exact frequency a DMR radio are sending on?
01: 143.4315
02: 143.4190
03: 138.9315
04: 138.9190
05: 143.5064
06: 143.4945
07: 139.0065
08: 138.9940
09: 143.2064
10: 143.1939
11: 138.7060
12: 138.6940
