ID's not listed for the Ft. Worth System
CLTX11
North Tx
I have been scanning the Ft Worth system and came across alot of ID's that are not listed anywhere. If anyone cares to see some examples ill post em up.
KE5BCP
Analog Man
Lewisville, Texas
Please post them, and if you can identify each one, submit them to the database!
CLTX11
North Tx
Thats the thing, I cannot identify them. Do I need to post them if I cant identify them?
FPO703
Planet Earth
You could post unidentified ones here and see if someone else might be able to help fill in the blanks.
CLTX11
North Tx
Ok here is the ones I caught:
944
1312
1392
2120
2144
2368
2400
2432
2464
2720
6544
7088 - This is the only one I caught something to give it away on, they used "Baker 4" I do believe.
7552
8864
13056
14736
15536
16976
25008
27216
27280
59872
VictorXray
Texas DB Admin
Some of the talkgroup IDs you have listed are not valid for a Motorola Smartnet system like Ft. Worth's. All valid Smartnet IDs should convert to an odd hex number (drop the 0 LSB). So if your scanner is stopping on a non-valid group, it probably didn't decode the ID correctly from the control channel (common with older trunk trackers), and what you're hearing is probably an image of a valid talkgroup.
These IDs you listed do not convert to an odd hex number:
1312
2120
2144
2368
2400
2432
2464
2720
7552
8864
13056
59872
