IDTracker III & BCT15X
RonnieUSA
Rowan County,KY (Morehead)
I'm trying to get IDTracker III v1.14.1 to log sql tones, and log them, but it's not working.
Anyone know how to get it to work?
This was the way I discovered unknown tones for frequencies that I have programed, because I'm not always fast enough to look, and write them down.
It's sure is different than when I use it with my Pro-197.
Thank You for any help on this.
RonnieUSA
Well it's recorded 1 so far, it shows them, but is not logging them.
Here is the log:
System ID/Freq Squelch Time Duration Description Unit ID Hits Signal Location
Carter County 155.83500 C127.3 02/09/13 10:15:23 0.79 E911 Center - Carter Co. S.O. 1 S62
Carter County 155.83500 C127.3 02/09/13 10:15:37 0.59 E911 Center - Carter Co. S.O. 2 S55
Carter County 155.83500 C127.3 02/09/13 10:15:42 4.80 E911 Center - Carter Co. S.O. 3 S62
Carter County 155.83500 C127.3 02/09/13 10:16:15 3.18 E911 Center - Carter Co. S.O. 4 S62
Carter County 155.83500 C127.3 02/09/13 10:16:23 7.37 E911 Center - Carter Co. S.O. 5 S62
Carter County 155.83500 C127.3 02/09/13 10:16:39 3.38 E911 Center - Carter Co. S.O. 6 S62
Carter County 155.83500 C127.3 02/09/13 10:16:44 6.24 E911 Center - Carter Co. S.O. 7 S30
I thought when ever You enabled logging it was a global setting, it logged everything?
RonnieUSA
Well it's not a global setting for logging with the Uniden like the GRE/RadioShack scanner, it looks like you have to enable it for each system.
I have now discovered this, and have it working, I think.
