if a digital frequency is scratchy sounding.....
bailly2
listening to it in analog fm mode, could that be why every p25 or nexedge frequency is 100% garbled when listening to it with dsdplus? thanks i covered the antenna cable the nooelecs sdr came with aluminum foil and stretched the antenna as far as i could from the laptop and its still like that . its a very strong signal, only 2 miles away
slicerwizard
Toronto, Ontario
Lose the foil. Sounds like you have some setting wrong. RF gain too high? Audio gain too high? Bandwidth too wide or narrow? Show us something. We're not clairvoyant.
boatbod
Talbot Co, MD
One of the problems with P25 is that it can be affected by multipath distortion if it's a simulcast system. Having a strong signal is not necessarily a good thing if you can hear two transmitters at once.
Now I'm not saying that's what you've got going on here, but it is a possibility. Try reducing the gain on the SDR dongle and see if that improves the decode quality. Does the control channel decode cleanly?
bailly2
not a simulcast system. i have tried turning the gain and the sdrsharp and the soundcard levels up and down and i have not gotten one second that isn't garbled.
