IFD Types of Incidents
kr19
Indianapolis, IN 46268
I'm noticing that, for the past couple of days, when a unit is dispatched, the incident type (Chest Pain/Heart, Stroke/CVA, etc) is often followed by a letter such as, "B" or C" and I'm wondering what these letters represent?
jknight8005
indianapolis, in
On medical runs it refers to the way they respond either emergent or non-emergent and the only thing that I've heard them using it is on Mental Emotional runs
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Been asked and answered many times over. Google "emergency medical dispatch" for specifics.
kr19
Thanks, I did that first, but since I'm not a dispatcher, I was hoping someone with local knowledge would be able to explain it.
kr19
Which one is more emergent, B or C? I'm trying to tell based on the units they send, but I'm not a seasoned enough listener to be able to tell.
h00sierdaddy
Lake County, IN
The scale goes from:
A "Alpha" (Least Critical) --> E "Echo" (Most Critical/Cardiac Arrest/Not Breathing)
There's technically an "Omega" that is even less than "Alpha", but a lot of places don't use it.
INDY72
Indianapolis, IN
And until very recently, these were NOT in use on locution, or aural dispatching for IFEMS. Only time you heard any codes were when an incident code was changed while the units were en route, and control would announce the change. About a week ago, this changed, and now ALL medical response calls have the letter code added. A lot of changes have occurred rather recently. No longer are IFEMS FD OPS TGs called FD OPS XX... They are now just OPS XX. Only Speedway, and Airport FDs still have any other designations. Airport is Airport FD OPS XX... Speedway is still SFD OPS. Most if not all IFEMS MDT/Laptops have been taken in to be redone, or replaced in last week or so also. This indicates some changes with the CAD system finally. And in the not to distant future, Pulse Point will begin use with IFEMS, as well as Westfield FD in Hamilton County.
kr19
You're awesome, thanks a lot!
Sent from my iPad using Tapatalk
kr19
I thought it was strange that Locution had stopped for a couple of days, but when it came back up that's when I noticed the codes being used. I didn't notice the changes to the TGs, but I'm still a novice to all this non-analog stuff. Thanks for all the info.
INDY72
Indianapolis, IN
Also, expect to start seeing some APXes on hips, and in units over the next couple of years, for IMPD, MCSO, and IFEMS.
Wonder where the XTSes and XTLes will end up recycled to? :)
N9IIT
Westfield, Indiana
Was this work the subject of that big lawsuit and IDPS?
INDY72
Indianapolis, IN
You're referring to the big TARFU/FUBAR with the old CAD at basically EOL and the failure of the second CAD which cost all those millions, that lead to back to the old CAD which is finally being redone etc? All I can say, is the situation legally is... fluid. Technically - things are getting fixed.... At least we didn't get hacked fully like Madison County did. All I can say is that the heads that need rolling over this whole crap shoot are no longer employed by IDPSC, and cant get rolled.... Lucky them huh?
