Ign Sense Hookup
Mattkuhar
New Haven County, CT
i have a TK-780 installed in my truck, and its been tapped into the fuse box (by me) to a totally unused fuse that happens to switch with the ignition (labelled for P/W) and the radio switches on/off with the key. however even if i turn the radio off first, it turns itself on when i turn the key on again. if i was to wire up Ign Sense would the radio stay off if i turn it off before turning off the truck? also, how which pin would i need to wire to in the accessory plug on the radio?
jim202
New Orleans region
Pin 3 on the accessory connector is the ignition sense input.
If you want the service manual, provide me with a valid email address. It is only a little over 4 megs in size.
