Ignition Sense - Motorola Astro Spectra
MOCOMD1
Is the 12v Ignition Sense connection of the 16 pin accessory connector absolutely needed to power on?
I have power connected so either the radio is bricked or it is required.
fineshot1
NJ USA (Republic of NJ)
If you are running all conventional repeaters and simplex then it really does not matter.
If you have a trunking system setup in the programing then the ignition sense is necessary
for deaffiliation on powering off via ignition +V loss.
yes it has to have it to work It is also your speaker connection
The speaker connection depends on whether it is a chasis mount or remote head mount.
If it is a chasis mount then you are correct. If it is a remote head mount the speaker
connection is on the control cable near the head end.
MOCOMD1
It is a trunking system, but not having the ignition sense connected stop the radio from powering on all together?
It is a chasis (dash) mount.
kb5udf
Louisiana
No ignition sense power = no power up
Ok I think the subject says it all. Yes, if you don't have power to ignition sense, the radio will NOT power up at all. In practice you can just connect the ignition sense wire off of the 16 pin connector to the same +12volt source as the main power cable, or splice them together right off the back of the radio.
You can read about all the pinouts on the connector on batlabs.
fineshot1
This is NOT a good idea and NOT recommended by motorola. As I said above it is necessary to
have the ignition sense hooked up properly for the radio to de-affiliate from the system. This may
seem trivial to most hams but is important from the system DB admins (or whomever runs the
trunking system) perspective. With thousands of radios on a trunk system it is necessary to
get this right as the DB admin usually reviews statistics logged by the system and can notice
such anomalies in the DB.
MOCOMD1
Where should the ignition sense connected to be "hooked up properly"? Any ACC connection? (IE: 12v lighter socket)
fineshot1
Any point in the fuse box that supplies 12V when the ignition is turned on.
I use the pig tail fuse tap kits from tessco
The ignition line that goes to the radio should be properly fused - i think moto
includes a 3 or 4 amp ignition fuse kit with the radio.
