Ignition Sense On 8180
btritch
Paragould/Greene County AR
If the Ingnition Sense only accidently gets checked on an 8180 where it can't be turned on or off by the Power switch, How do you fix that? It's gotten checked and won't come on and when I turn the ignition on or start the car it won't as well. Just wondered if there was a specific way I had to do that?
For some reason when I start the car the VHF which is set that way on purpose comes on, But the 8180 doesn't and it was accidently set.. What's the way to fix that.. I hope there is one!
jim202
New Orleans region
Let me ask the big question here. You did run the ignition feed through a fuse to the correct pin on the accessory connector didn't you. There is +12 volts on that pin when the ignition is turned on as measured with a good voltmeter I hope.
btritch
It's actually hooked in direct to the battery thru a fuse. I may have to rewire it to an accesory to get it back on. but it's actually hooked directly to the battery as is the VHF but it works correctly for some reason.
ramal121
Sonoma, CA
Ignition sense has two options, ignition / power switch and ignition only. Sounds like you have the latter programmed and it ignores the power switch. Try pulling all power to reset the radio, hook the red/black power wires back first, then apply 12 volts to the yellow ignition sense and see if it responds.
btritch
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.3; en-us; HTC-A9192/1.0 Build/GRI40) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
I only hooked up red and black to the battery itself thru a fuse. Never saw a yellow. Where is it?
btritch
jrw14493
It emits from the back of the radio next to the red and black one and has a black cap on the end of the wire.
btritch
Wirelessly posted (Mozilla/5.0 (iPod; U; CPU iPhone OS 4_3_5 like Mac OS X; en-us) AppleWebKit/533.17.9 (KHTML, like Gecko) Version/5.0.2 Mobile/8L1 Safari/6533.18.5)
Yes I have found that now, never knew why that was there...got it fixed and working now...thanks again guys!!
