Ihp ?
fredmertz51
I no longer get ANYTHING on IHP 155.640 or state of Iowa on my BCT 8. Frequency change, or scanner problem?
JLM7424
Williston,ND - Williams county
What part of the state are you listning in ?
It's Hard to say they may be going P25 digital in your area, They seem to be intergrating it here and their.
timkilbride
Linn Co Iowa
If you have your CTCSS on, you won't hear the digital signal. If your hearing a digital signal, you will know. You won't be able to stand it and will want to lock the channel out.
fredmertz51
That's why I'm confused. I get no signal whatsoever. With no CTCSS enabled. Manually entered 154.220 County Fire works, but 155.640 IHP has nothing.
JLM7424
I Would suggest scanning the 154-156 range for a bit and see what you come up with see
If you recongnieze the dispatcher or the dispatch center city name in the traffic call.
About all i can suggest.
I do have a bcd 996t for sale $400.00 brand new condition
has only sat on my desk never moved . over in western iowa
Good lucK!
mws72
Quad-Cities (IA-IL) USA
Good lucK!
I heard traffic on 155.640 last night. From time to time you may not hear anything due to staffing. Last weekend no one was off, so for the rest of week there was less troopers.
burner50
The Third Variable
NC Iowa
I've been hearing it all day.
fredmertz51
May have figured it out. Been running a 6" rubber duckie in the past and everything was good. Then, IHP disappeared. Went to the 9" duckie and IHP came in weak. I tend to believe that the local repeater went down. Now researching better antennas.
