N
N_Jay
Guest
Sure they do - P25 is as good an example as any.
Shelley
K0SHL
Explain why you believe this?
Link? Example? Rational? etc.?
Shelley
K0SHL
Oh, and my sources are the system people I've worked with over the past many years.
Shelley
K0SHL
Shelley
K0SHL
No one said you were stupid.
Maybe you can explain it to me the way they explained it to you and we can find the point of confusion that either you or I am having.
My guess is they were using the term incorrectly.
P25 uses a 9.6 KBPS data rate for both clear and encrypted.
There is no difference in bandwidth used over the air or on the back-haul network.
In the past DVP/DES (11 KBPS CVSD) encrypted systems used a wide-band modem on analog microwave systems, so that could be an issue but it was not used dynamically so once set up there is not change with user loading.
Also older systems used to have a limited number of channels equipped for encrypted use, so if everyone was running encrypted they were sharing a subset of channels instead of all the channels. In P25 there is no reason to do this unless someone put an artificial limit somewhere in the system.
I hope this helps.
What exactly does "radio access" mean? Can some official reasonably interpret it to mean receiver?
Re: Anti-rebroadcast: I'm disturbed by it but also not really surprised by it. If interpreted as being more restrictive than what's allowed by Section 705(a) of the Communications Act of 1934, then I'm against it like everybody else here.
Re: Listening...
If I were visiting IL, I'd listen on my P25 commercial gear instead of my scanners given that it's what I use on the ham bands and therefore counts as my ham transceiving equipment so the ham federal preemption of state anti-scanner laws applies.
Also, how does IL get around the "it shall not be unlawful" clause in the Electronic Communications Privacy Act of 1986 (ECPA '86)? ECPA'86 specifically states that it shall not be unlawful to monitor public safety comms. It seems that if listening to public safety comms were expressly prohibited by state law it would directly conflict with ECPA '86.
I'm not a lawyer, nor do I pretend to be one either. These are my opinions only, so take them with a grain of salt. Don't listen to anything I wouldn't listen to. <wink>
Obviously, monitoring isn't the issue, which I believe is all ECPA '86 covers and I don't think addresses rebroadcasting. But I may be incorrect. Also, as far as I've been able to find, there hasn't been anything close to a test case yet on rebroadcasting. So this may be it, if Illinois does pass the bill and, of course, if someone/some entity challenges it.
I too am not a lawyer nor have I done any Lexus/Nexus searches on this. (And probably won't.) I have though written to all of the representatives on the committee expressing my "concerns" about the path they're going down with this bill. Given the Illinois track record on such things and the fact that I reside only in an adjoining state, I doubt my emails will elicit any responses.
Shelley
K0SHL
I love how these tools try to control the internet. Give me a break, like a law can stop someone who is hell bent on doing it anyway.
If this law passed here in AZ, I'd do 3 things:
1. Change my feed here on RR to anonymous.
2. Route the stream itself thru an anonymous proxy in Prague.
3. Sit back, drink a beer and laugh. F*** 'em if they can't take a joke.
-AZ
However, the U.S. Supreme Court has said that routine police business is the kind of activity that falls under important public interests worthy of protection.
