AngWay
Curious
Ok i have looked at tons of antennas and i am confused on a few different things for example a dual band and a tri band antenna if the tri band lets you cover more why would people even bother with a dual band is it because that if a antenna is programmed for a specific freqs it will pick up that freqs better than a dual band antenna?
Next everything i listen to is between 150-160 450-460 and 850-860mhz so i need something that will pick up those the best. i am looking at the Larsen NMO150-450-800 Tri-Band Nmo Antenna and NMO150/450/758 - Pulse Larsen Tri Band Antenna with Spring, NMO the only difference i see is one says 800 and one says 758 what is the big difference here to me they both cover the same thing except for that last number. so what is the difference and which one would you advice i get?
as far a a magnetic mount which one do you guys suggest? as far as connection type i would like to be able to connect different antennas to it and keep the price around 30 dollars.
What do you guys thing about those signal sticks? i'v heard alot of youtuber's talk good stuff about it
Many Thanks!
Many Thanks!
