State Police mobile repeaters... Hamilton County, KSP for Kentucky,
What type of scanner, you need digital to hear the most, but there are files from both GRE/RS and Uniden available.
I have a pro-96 and what are the frequecncies for the mobile osp repeaters?Are they the mobile extenders?And all i need is the control channel for these counties and the pro-96 will track the marcs sites in these counties?
Load all of the MARCS Control Channels for the counties you will be driving through into a single bank and then add the Talk Groups for the OSP regions assoicated and and you should be good. Remember to also include the TAC Talk Groups and you may also want to put LEERN and STATEWIDE in between the Control Channels. I would not worry too much about the OPS MARCS mobile repeater since you are just passing through.
If you want to hear only OSP then use the scanner in Closed mode; if you wat to hear everything on that tower, use Open mode.
Load all of the MARCS Control Channels for the counties you will be driving through into a single bank and then add the Talk Groups for the OSP regions associated and and you should be good. Remember to also include the TAC Talk Groups and you may also want to put LEERN and STATEWIDE in between the Control Channels. I would not worry too much about the OPS MARCS mobile repeater since you are just passing through.
Mobile Repeaters just give a heads up, saw six OSP and one sheriff car last Friday, but got the "warning" sooner that some were nearby... but they always sit on the Delaware/Franklin line.
