Import CSV into Favorites Lists (Conventional)
rogress
Chesapeake, VA
Hope I'm not asking a question that is staring me in the face somewhere in the forums. Using the Sentinel software, is there a method to import csv files into a conventional favorites list? I've already done this in my TRX-1 and -2 scanners, but would like to do the same with my SDS scanners.
If no using Sentinel, is there other software that allows me to do with with the SDS scanners? I see references to .hpd format which apparently is plain text, but I don't see the option for this using Sentinel software.
Thanks.
rogress
Chesapeake, VA
That's a thought - I'll give that a try.
I did see where Proscan lets you export to CSV, but I did not see in import from CSV.
I've cut & pasted from csv and Excel many times. It just has to be formatted to match - column to column.
hiegtx
Dallas, TX
It does not import CSV, but if you copied your CSV file to the clipboard (or copied database details directly from a web page), you can specify which columns go where in the Favorites editor (specify which column is the TGID (or frequency), which is the name, etc.)
But as phask has already noted, you can also copy from your CSV file & paste that into the Sentinel Favorites editor.
