Import XPR7550 codeplug to R7?
james_garner
Fort Worth
I am trying to import a 7550 codeplug into CPS in order to program my R7 with the same information.
Is it possible to convert/import a 7550 codeplug into an R7?
FFPM571
Nashvillle
Open your 7550 , Open another copy of CPS, Read your R7. copy the 7550 configuration and drop it on to your R7 configuration. Fix any validation errors .. write
30319
Fabulous KnoxVegas
Can anyone tell me if the programming cable, speaker mic, battery & charger of a 7550 will work on an R7? Thanks in advance!
K2NEC
5F6
-Programming cable- No
-Speaker mic- No
-Battery- No
-Charger- Yes
Asunakiyori
Lurker
Hiding in a Shed somewhere
The r7 has a completely different connector and hold down instead of clipping over the frame, it slides under and in. its also thinner so almost all new accessories for you
