Importing File Into Scanner (Win500) Data Base
PortRichmond
Philadelphia, PA
I am having a problem figuring out how to import a file
from the Data Base and download File and import it
into Pro-106 via/ Win 500 Software
Any help is appreciated..
t0xPro-197
Maggie valley North Carolina
im still learning this stuff should be away too import i use the defult that came with my pro197 just takes tril and error id say go too the file then open file the file and click it it should open it up then impornt too scanner when i figg it out ill make avid on it sorry i cant help more as im new too this style of programming but ill ask around hopefully someone who knows way more then me can help you better God bless :/
hiegtx
Dallas, TX
If you haven't already, take a look at this guide for Win500.
Remember that once you import information, via the software, whatever you load from the software to the scanner overwrites the programming currently in the scanner. You can't simply add a few newly imported channels, or an additional trunked system.
Instead, if you already have a certain amount of channels, and/or trunked systems, loaded, and want to add additional conventional objects (frequencies), or TSYS and TGRP objects (trunked systems and talkgroups), first download from the scanner into software, then save what you have already programmed. Then, using the file you've saved in Win500, make your changes and additions, save that (as a backup), then upload it to the scanner.
Also see this page for an overview on the Object Oriented memory used by your scanner.
NHdave
Southeast NH, USA
In Win500 click File > Web Import > RadioReference.com, select the type, enter your RR logon info, then select country, state, etc., once you've selected your specific services, click the Import Selected Channels button. Once you have everything arranged how you want in Win500, click Scanner > Upload to Scanner.
RonnieUSA
Rowan County,KY (Morehead)
I think the only type of file You can import to Win500 is one that was created by a program made by the developer of this software.
There is No CSV support, You might be able to import a bin file, but I haven't tried that.
t0xPro-197
something ill have too learn more on only got 30 days too use win500 but ill learn it thwen buy it when im able too i just did a test it worked fine and redid my radio runs smooth then hopefully ill be streamming live anywho hope everything works out :)
