ProScan: Importing Radio ID's
mikewazowski
Staff member
Central Ontario
I tried to import a bunch of Radio ID's into Proscan using the Get Clipboard utility.
I manually added an "i" in front of each numeric ID so my 996P2 would recognize these ID's as Radio ID's not talkgroups ID's.
When I try to import these into Proscan, it doesn't recognize them because of the leading "i". When I import these as normal decimal number, Proscan does import them but my scanner doesn't recognize them as Radio ID's.
Would it be possible to either allow the leading "i" or have a checkbox to denote the numeric ID's as Radio ID's and have Proscan automatically add the "i" in front when being imported?
mikewazowski
Staff member
Central Ontario
The other solution is a Find & Replace operation since the first 3 digits of every ID is the same, 104xxx.
I've tried various ways and I'm unsuccessful in converting 104xxx to i104xxx. I end up replace the whole ID with i104.
