Since I couldn't find the instructions on how to do so in the manual (Or I am blind and missed it completely ), how do I go about importing the RRDB into proscan and add channels from the DB to a favorites list?
Oops, then I was definitely blind
Of course,Can I suggest you put all your programming questions in this thread, instead of creating a new thread for every question. It will help others follow your progress.
It's pretty easy since you provided the link. The link ends with sid/12719When programming a DMR trunked system, how do I know what system to choose?
Trying to get United Airlines DT3 programmed into my scanner and not sure what DMR system to choose.
That makes programming even easier.It's pretty easy since you provided the link. The link ends with sid/12719
Steps
1. Go to the Direct Entry tab then select the option 'sid' and enter in 12719.
2. Click the Retrieve Data button.
3, Go to the Select tab.
4. The grid should be populated with the system data, Uncheck the items not to be imported. The items labeled 'Freqs' are the Sites.
5. Click the Import button.
{edit} Before uploading to the scanner, you may want to go over the system, site, department, and channel options, especially the names to make sure they are how you want them to be.
Just wondering now, what the aid option is used for above the sid option in the direct entry tab?
ProScan can also utilize the Sentinel database for creating FLs, but it doesn’t download/update the Sentinel database. You would have to do this in Sentinel.It imports right from the online database and doesn't store the database on your computer.
