importing trunked systems into software from rr.com
jim49
S. Carolina
I am using trial psredit500 & arc500 software to decide which I will use with my gre psr-500. When connected to rr.com to import a trunked system what import option should be used *primary cc's only* *primary & alts only* *all site freqs* ? should I use *all site freqs* so everything will be covered or will this slow scanning down?
dsnymj
Seminole, FL
As a general rule, I use "all frequencies" if they will fit into the TSYS definition to avoid missing control channels which aren't flagged in the RR database. Otherwise, I'll use "primary CCs and Alt" followed by "primary CCs only".
I don't think it slows anything but the initial CC acquisition to have all the frequencies in the TSYS. I know having all frequencies present saved me a couple of times on my Pro-96 because the database hasn't always had accurate CC information on some systems.
Mark J.
jim49
S. Carolina
Mark J.
I'll be importing them all then. Thanks for your answer Mark.
