"Impossible" FM radio signals in Peruvian Andes?
p1879
18 years back I was in a small bus ("Combi" Van) that traversed the route Leimebamba- Celendin in the northern Amazonas region, that crossed the massive Mara~non gorge. At the bottom of the gorge, in Balsas, you cross the river into Cajamarca region.
At the top, on the Amazonas side, is the 3500 Meter-high Calla Calla Pass. This is in itself not remarkably high in Peru, but the view from this spot is extremely dramatic, even by Andean standards. I was riding up front with the driver, and I asked him about radio reception along this high spot. He told me it was amazing, and said you could hear Lima radio stations from there; he turned on the radio, tuned around, and demonstrated a station from Lima on the ordinary dashboard radio.
Google Earth says this is 610 KM to the Morro Solar TX site used by almost all Lima stations.
I would call BS on this assertion on the surface, but Peru is really a land of many mysteries and miracles, as well.
Many major radio outlets, like RPP Noticias, and Radio Nueva Q, do have stations all over the country that carry their programming, but he said you could hear numerous stations from that high point , that actually were in Lima. I got to know the gentleman, and his son-- who also owned the hotel I stayed in during my stay in Celendin-- and they were very honest and trust-worthy folks. The only place that had any radio stations in possible line-of-sight from there were below in Balsas, about 30 KM downhill. Even then, the river bottom at Balsas is not visible from up top.
The stations listed on the Peru Ministerio de Transporte y Communicaciones website in Balsas have 100W, and 50W respectively. I am sure he knew them well, from years on this route.These folks drove this route both ways, once a week, and were familiar with every curve, and knew all the folks we encountered along the route. I feel certain his statement about the Lima stations was true.
Now, map direct-lines and radiogoniometric plots can differ, depending on the type of map. On the Google Earth map (which I am having difficulty pasting here) shows the path to Lima from Calla Calla passes over the Cordillera Blanca, which has Peru's highest peak-- Huascaran,-- at 6700 Meters high. Huascaran, for example, has a 2000 Meter snow and ice wall on it, and many adjoining peaks have huge snow and ice ramparts.
The distances, and obstacles, sound insurmountable.
I realize this must sound like a radio fairy tale, but I have to seriously wonder if Calla Calla gets some type of signal refraction from the Cordillera Blanca, or has an unusual climatic condition that somehow creates frequent ducting into it. Yes, I fully understand the curvature of the planet over this enormous distance, and the other factors, as well.
Not offended if you don't believe it, just my true experience.
Enough of my wordiness. How could this be?
p1879
NMO's installed, while-u-wait.
None of that really surprises me, but it is always fun to see it happen in real time and in the real world.
FM broadcast is in an interesting part of the spectrum where ducting can absolutely happen. Lots of stories about people in the UK picking up US FM broadcast, TV, etc.
Altitude obviously helps.
RF can reflect of things.
Ducting happens.
Good antennas.
I've experienced some interesting FM broadcast stuff, but not quite that good. Enough for me to think it's entirely possible.
If this part of Peru experiences this all the time, not just periodically, then it's probably not ducting, unless ducting happens all the time down there.
Another factor here may be that there just aren't that many FM broadcast stations, so co-channel interference isn't a thing. With a good clear frequency, amazing things can happen.
p1879
The explanation of this phenomena is beyond me. Admittedly, if such a miraculous propagation path did exist, you would think it would be a well-known and studied affair. It is always possible it was indeed some other city that carried programing from Lima, and my "chofer" was not correct about direct reception. But I feel he did know what he was talking about. It seems unbelievable, but there are many strange things in that marvelous place.
I mentioned ducting to cover that base, but my indication was this is a common occurrence at that place. I am including a link to a fantastic Adventure Motorcycle Riding Blog by a Danish couple who recently passed through the Calla Calla pass. They have a picture that shows the view from an overlook at the Canyon. The geography there is most impressive. I was 100 meters off on the pass elevation. It is at 3600 M. It was still a dirt road when I was there.....
Speaking of Nevado Huascaran, Peru's highest point, 6768 Meters is 22,205 feet.
Stunning scenery.
It's entirely possible it is the same broadcast transmitted from different locations, that's a common practice.
But like I said, if there isn't a lot of frequency reuse in a mostly rural area, FM can carry quite far.
RFI-EMI-GUY
"he turned on the radio, tuned around, and demonstrated a station from Lima on the ordinary dashboard radio. "
Radio propagation has at its basics, statistical probability. Had he said, I receive this very station every single day, I would be skeptical. It may occur 5%, 25% or 50% of the time. But he would probably have been able to receive a distant station from some other direction a day later.
I was amazed decades ago, to receive MILSAT communications from the pacific northwest on my Regency MX5000 using a simple discone antenna in Miami Florida. Of course a satellite was involved. But then years later the same receiver picked up TV audio and FM Police transmissions from Cuba. My Sony TV with outside antenna was able to receive TV channels up to 13 from Cuba at same time.
krokus
Southeastern Michigan
Ducting can be interesting. I once received a small town FM station from New Mexico, on my vehicle radio, in southeast Michigan. I figured that someone was using a low power transmitter, from an online feed. I called the station, and the DJ said that they have no streaming of their signal.
KB2GOM
Rensselaer County New York
Not to hijack the thread, but FM DXing fascinates me, yet I am a total newb regarding FM DX.
So, my dumb@ass question for the day: is there such a thing as "graveyard frequencies" or perhaps certain frequencies where one ought to look for FM DX, or can it happen anyway on the FM broadcast spectrum?
KB2GOM
Perhaps someone could point me in the right direction.
nd5y
Wichita Falls, TX
Here is a list of all US FM broadcast frequencies.
See the links below the table for looking up US stations.
You won't be able to hear DX on frequencies used by your local FM stations.
Depending on your receiver it might not be able to receive weak DX stations on channels adjacent to your local stations.
KB2GOM
StoliRaz
Masshole
The only DX on my radio that I've ever caught was an FM station from Pittsburgh. I happened to just stop and listen to it. They talked about the Steelers, Penguins, traffic report was all Pittsburgh highways, later confirmed online. Nice clear signal from 470 miles away. Went on for several nights in a row then faded out.
I was getting a Canadian weather station from Nova Scotia last night too, just scanning the marine band for the hell of it. French and English. 300 miles across the water from me. Fun stuff.
BinaryMode
USA
Well, let me tell you something about FM broadcast reception. I went to school in Utah and frequently flew back and fourth between Denver and Salt Lake City. On a flight from KSLC to KDEN, I decided I'd see if my FM/AM cassette player Walkman would perhaps be able to pick up any radio broadcasts. Sure enough I did hear an FM broadcast station and if memory recalls it was 103.5 The Fox (KRFX). KRFX - Wikipedia
Though, that sucker is Xmitting 100,000 watts ( I think the strongest in CO). LOL So maybe not so significant after all. But! I was not even near crossing the Rocky Mountains yet either. Typical average elevation for a commercial plane is around FL350 or 35,000' (10,668 Meters).
For a great alternative to Google Maps I highly recommend ACME Mapper 2.2 I use it all the time with GPS coordinates, plotting things and all around research. Especially since I try to avoid Google as best as I can. But that's just me. "mapper" is the subdomain. ACME Laboratories
This may sound a little dorky, but looking at those photos of Peru reminds me of the game ARK: Survival Evolved. And dorky part deux, being a Flight Simulator hobbyist and flying around the world at least five times, I believe it's Peru or that general area that has the highest airport elevation in the world. Thus the runways are very long in an effort to get off the ground due to density altitude. Been there in the Sim a couple of times.
Everywhere I go in the Sim I visit the place in Google Street View. Perhaps one of the few Google web properties I use. I absolutely love Google Street View though. I can go anywhere and see things I'll probably never see in my entire life... You can even see 360 degree panoramic views of North Korea. The areas that they allowed Google to photograph of course.
Not FM tropospheric ducting, but on the AM side of the coin I heard an AM station in Colorado from Utah as if I was still in Colorado. That, I thought was pretty cool. Cool in that was before I ever owned a shortwave radio.
dlwtrunked
Thank you. Very helpful!
Someone who can should fix that page. The correct abbreviation is "MHz" not "Mhz". At least they got it right on 1 out of 3 uses on the page. Yes, it makes a different "Hz" (for Hertz) was a persons name and even in units, the first letter get capitalized by international unit standards which RR certainly would like to use.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You can fix the page yourself. With the exception of a few articles which anchor the wiki, any member can change any of the literally thousands of pages we have there
Mike
