tropiradio
- Joined
- Mar 10, 2021
- Messages
- 237
- Reaction score
- 24
When one powers up almost any modern Motorola TRBO portable radio equipped with display and that is also using an IMPRES battery, after the initial boot sequence the radio and after the channel display has come up, there is this brief popup message identifying the installed battery as being "IMPRES (TM)".
I am well aware that this popup only lasts about a second but at least in my case after a while it gets kind of irritating, specially when you already started to dig into the menus of the radio or are trying to change channels, etc. Then the popup just opens right on top of what you where trying to do and one has then to wait what sometimes seems an eternal second for it to go away before you can continue doing what you needed to. It even comes up when you try to check on the battery information.
Its reminds me of those irritating advertising website popups that where so popular some years ago, but have now fortunately gone away thanks to build-in browser popup blockers.
Has anybody ever felt about this popup the same way, and perhaps found a solution to get rid of it? (Aside from getting a non-display radio). I know the popup code is probably embedded right into the radio firmware, so not easy to mess with it at all. But given so many advances in hacking and reverse engineering this and that lately, I though I just put this out there for discussion.
And if nothing else, perhaps at least find out if I am the only one that is annoyed by this popup, or actually others share my opinion.
