Impres charger does not repair the battery
bg5gnc
ZHEJIANG ,CHINA
I have an APX battery, impres2 battery, but I found that the battery cannot be repaired when charging with HTN9000C, And the number of charging reaches about 5 times, it is almost not charged (10 minutes will show full), you must get the APX special charger to repair before continuing to charge on the HTN9000C normally.please see the charger label, what is this?
IMG_20230809_165534.jpgIMG_20230809_165542.jpgIMG_20230809_165603_edit_788840829720776.jpg
K2NEC
NA
Not sure what you mean by repair but Impres chargers don't repair anything. They condition the battery to get the most out of service life. Impres batteries will not bring back dead batteries. The HTN9000C isn't even an Impres charger nor is it for the APX series. If your battery is dead, get a new battery.
WRTF671
That looks like an aftermarket charger which will not be able to recondition an IMPRES battery. I'm guessing they use an impres sticker on everything. For the record it is possible to fit an APX 6/7/8 battery in an HTN9000C (I actually have both chargers on my desk) and the lights come on but that's as far as I went with this, I'm keeping my batteries with their respective chargers!
bg5gnc
ZHEJIANG ,CHINA
I mean Reconditioning.
bg5gnc
ZHEJIANG ,CHINA
The HTN9000A HTN9000B HTN9000D doesn't have a recinditioning sticker, only the HTN9000C does, and I'm pretty sure it's an original charger.
bg5gnc
ZHEJIANG ,CHINA
On MOTOROLA's official website, they call this charger intelligence charger, intelligence charger is not the early name of IMpres?
WRTF671
It may be related but I doubt it is the same... I have an HTN9000C in front of me and there is no reconditioning sticker on it, just the conventional charging sticker. Regardless it is NOT the right charger for that battery. Get the right charger and I bet it will work.
K2NEC
NA
Regardless of what it says, the HTN9000C is a Waris series charger and isn't intended to fit the APX series batteries. Buy the right charger and you won't have an issue.
mbnv992
AZ
That battery was made in 2017 and is now 6 years old. Toss it in the bin and get a fresh one.
