Improper Channel Spacing
adamr368
NJ
Does anyone know any tricks to getting RPM 14 to accept an 800 Meg control channel in 6.25 KHz spacing? I get an "improper channel spacing message" when trying to enter say 851.21875 versus 851.2185. Hoping there is an easy workaround, but couldn't find anything in my searches here or elsewhere. Thanks!
merlin
DN32su
Do you have 'NSPAC' ticked ? un-tic that.
--default channel IDEN set--
In the IDEN SETS group make sure your base frequencies are set right. (851.00625 -45.00000 and 6.25 Khz channel spacing. 12.500 Khz bandwidth. And FDMA FULL RATE.)
That works for me anyway.
adamr368
NJ
NPSPAC disabled and IDEN table is 100% correct. Still unable to enter a 6.25 KHz frequency without getting an error. Interestingly, I get the same error when attempting to add a conventional frequency as well.
merlin
DN32su
Can you make your set scope local.
Also check the offset for the frequency you are entering.
merlin
DN32su
A good question: where are you getting 851.21875 as a control channel frequency ?
adamr368
NJ
That was just a conventional frequency for illustrative purposes. Actual CC is 857.21875. Wondering if there is a way to crack open the global sets list to edit the freq manually so the software doesn’t have a chance to touch it…
mikewazowski
Forums Manager
Oot and Aboot
Could the radio be too old to support any frequency out of the ordinary?
cg
Connecticut
There are no FCC licenses for that frequency. There are no RR database entries for that frequency. Perhaps the agency you are programming to monitor can help you with it.
a417
ahhh..no.
You'd likely be the only one on that frequency, and no one would here you. (actually, considering how close .21875 vs .2185 in your example are - you might hear some of it) , I'm leaning towards you having the incorrect information for that system.
I'd verify either with the system operator/contact what the frequency is, or present the correct listing in the RR DB so we can figure out what frequency you're really supposed to be on.
There is a hacky sort of way to use the "close but not exact" frequency when you are using NFM splinter channels on older WFM hardware, where you would program in the closest correct frequency and then listen in wideband mode - you would hear most of the conversation, and it would usually sound terrible - but it kind of worked, but not in this case.
adamr368
NJ
Thanks for the feedback - someone had asked me if I knew how to add that spacing so figured I would reach out to the broader group since I couldn't figure it out. Everything works great on my G5 and SDS scanners, so probably a matter of outdated equipment on his end.
merlin
DN32su
You can edit the IDEN sets. Global sets you edit setting up your system. You can always start over and do it different. the 857.21875 would be a good CC and should be no problem with 6.25 Khz spacing.
GTR8000
NY/NJ Database Guy
BEE00
Not to throw a wet blanket on the "that's not a valid frequency!" party, but the data for the system he's referencing (NJICS 39A) is 100% accurate. The state has started to incorporate 6.25 kHz 800 MHz channels at some sites. No, they're not actually licensed for those center frequencies, but they are licensed for the nearest 12.5 kHz center frequency in most cases. APX CPS accepts them with no issue.
K2NEC
I'm also not quite sure why you are trying to TX on 851.21875. That should be in the RX box. Unless you get the same error in the RX box too...
My XG75m doesn't like any of the higher end 85x.xxxx on NJICS either. Probably worth an upgrade
