DSDPlus Improve P25 Simulcast audio decoding
maus92
The OP
So the (mostly) successful resolution to this issue was to try a different antenna. I have a portable antenna that I have tried to place in a location to optimize reception of this system with my scanners, which is an exercise in futility. But connect that antenna to the dongle, as opposed to the smaller direct-connected antenna that I was using proved to improve reception and audio, with many fewer dropouts. It's far from perfect, but considerably better than it was. Thanks to all suggestions.
Makes sense, as your s/n wasn't stellar. You *might* want to revisit gains adjustment since your antenna system has changed, and tweak ppm (after the dongle has warmed to normal operating temp and stabilized.)
brian
DB Administrator
South Carolina
Thanks. Yep, I have now done those things. Decoding isn't perfect, but probably better than 80%. Much better than before. Thanks again.
jets1961
Download the program DSDtune. I think it's on this site, only used it a few times.
Think you have to record raw audio then feed it to DSDtune, it then spits out a file that tells you how to set; -dsxx -ddxx -dvxx values where xx are values in numbers 00.
The longer the raw recording the better the output.
