improve train Wi-Fi by laser-treating train windows?
Pittsboro IN
Never heard of this, can't imagine the train windows are E glass, how many people in Finland try to avoid solar heating?
Finland has seen something of a heatwave in recent days, with temperatures edging over the 25 degree Celsius mark that tends to mark conditions regarded as properly 'hot'.
A quick way to do C to F is to double C, subtract 10% of the result (basically the left digit), then add 32.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
So...... where is the wifi coming from? Typically, we put wifi access points inside the train and external LEO or cellular or NITRO LTE antennas outside the train.
If you are on wifi, but have no internet, then you have a technical issue unrelated to the glass coating.
TT
Pittsboro IN
I think they get wifi confused with LTE or their version and they think lasering the windows will let more cell signal in to offset the wifi with poor WAN feed. Still confused about what the treatment is.
AB5ID
Lee's Summit, MO (Kansas City)
Pittsboro IN
thanks, I wonder if that's an option from the glass mfg. I imagine you guys working in the DAS field have better isolation with E glass than normal glass.
