In Search of Courier Gladiator 13.8V DC Power Cord
samuhinso
I recently came across a Courier Gladiator that was sold as untested. Was curious and decided to buy hoping it would work. Unfortuntely, it was untested because the power cord is nowhere to be found. I cannot find the cord to the unit and need help finding a replacement. I found a 2-pin 13.8VDC power cord with no wall plug in attached. Is this the best route to take? Attached is picture of replacement cord.
Thanks!
138BG
Worst case you could use the cord in the photo with a 13.8vDC power supply. Isn't it a mobile radio? Confused I guess on what you're looking for. Wall plug??
cmjonesinc
If you're needing to plug it in to a house outlet that cord will be fine.... But you'll need to purchase a power supply to go between it and the wall.
samuhinso
Yes, it is a mobile radio. Would this be the easiest way to test and see if it works? Anyway to bypass having to buy and hook up?
cmjonesinc
Wiring it directly to a car battery would do the trick.
