Increase Reception Speed Warning Message on Unication G5
brian86
Maryland
Anytime I try to navigate away from Menu E6 Group ID Settings, I get this almost non translatable message (See Photo). I have these set to none as it is telling me to do but the message continues to pop up. Any suggestions on how to get this message to leave me alone or am I getting this because I haven't changed the correct settings?
hazrat8990
Wyoming
That tab is for conventional stuff only, so if your agency of choice is paged out over analog or P25C, that's where you would enter info. If paging and monitoring is done on P25 phase 1 or 2, just ignore that tab entirely.
brian86
Maryland
I am using conventional two tone but why would it tell you in the prompt to turn off alerting? Like the entire point of the pager is to alert for two tone activations.
hazrat8990
Wyoming
In that case, once you set up your tone pair on that tab, you would then set the alert tone to whatever you wish. Tone 3 sounds similar to the Minitor.
