Indiana Radio Data for Railroads out of date on this site?
KC9JUM
Indianapolis, IN
I noticed some of the data for CSX is woefully out of date for the former CR lines on this site...... anyway this can be updated?
They have moved to a Road and Dispatcher channel style for the ex CR lines.......
Pair 1 (IB Dispatcher) (St Louis Line Subdivision)
St. Louis Line Subdivision Road 160.230
IB Dispatcher 161.070
Pair 2 (IC Dispatcher) (Indy Terminal)
Road 160.800
Dispatcher 160.560
Pair 3 (ID Dispatcher) (Indianapolis Line Sub)
Road 160.800
Dispatcher 160.680
Some other things need some general cleanup as well.. there are some CSXT lines missing.... the ex B&O Across northern Indiana. the ex Monon...
I run a Railroad Feed from Indianapolis IN. Feel Free to visit.
http://inrd.gotdns.com/inrdradio.htm
scannerfreak
Moderator
Indiana
Submit to the DB what needs to be deleted and what needs to be added. Preferably, to make it easier to understand, you can format it the way it should look in the DB. Thanks :)
AK9R
Super Moderator
Central Indiana
I'd be glad to help work on this. I actually talked to Steve about it several months ago, but got busy with other projects and didn't follow through.
My suggestion for organization would be something like this:
Code:
CSX
  |--Indianapolis Line (Union City to Indianapolis) - ID Dispatcher
    |--160.800 Road
    |--160.680 Dispatcher
  |--Indianapolis Terminal - IC Dispatcher
    |--160.800 Road
    |--160.560 Dispatcher
    |--xxx.xxx Hawthorne Yard
    |--xxx.xxx IU "Belt 1"
  |--St. Louis Line (Indianpolis to Terre Haute) - IB Dispatcher
    |--160.230 Road
    |--161.070 Dispatcher
  |-- Avon Yard
    |--xxx.xxx Hump
    |--xxx.xxx Puller
    |--xxx.xxx Car Inspectors
NS
    |--xxx.xxx
    |--xxx.xxx
Hopefully, that gets the idea across.
KC9JUM
Indianapolis, IN
Perhaps we could collaborate on something W9RXR, work up something in email and submit it. I have a lot of notes on RR frequencies. I even have some odd things,The Amtrak Beech Grove UHF repeater frequencies.
Your call would suggest that your a railfan. Have you visited my online stream?
A few quick notes on what is there,
the 4 Indy Belt channels are used as switching channels now... Dispatching for the belt is on the IC Dispatcher pair
Hawthone bounces around between these channels, and the Indy Road channel, as does the Transfer yard.
The Avon Car Department at avon has/(or had) a repeater on 160.650mhz.. I have the input here somewhere......
The two CSX Police frequencies were re farmed into the dispatch channels.
for the CSX Garret Subdivision.... the B&O across northern Indiana.. here is what it looks like
CSX Garret Sub road channel 160.230
CSX Garret Yard Operations Channel 161.160
CSX Garret Yard Switching Channel 160.320
CSX Garret Sub Dispatcher160.290 Chicago to Garret (Calumet City)
CSX Garret Sub Dispatcher161.370 Garret to State Line Ohio (Calumet City)
I also noticed for the NS that Elkhart and the Dearborn division are missing..... Chicago Line, Kankakee, others....
I will need to dig that stuff up, although the main road channel up there is 160.800
Shawn
KC9JUM
tommybza
nw indiana
I have found 161.370 i can only pick it up on the am setting
this is CSX henderson sub acording to the info i can find ?
could CSX sharring the freq. with some RR up in the NW indiana area .
or is it old news .
Tommy
KC9JUM
Indianapolis, IN
CSX uses 161.370 as road on the Monon and C&EI. It's also used as a dispatch channel in Michigan and Ohio.
I am working on a revised frequency list.
KC9JUM
Indianapolis, IN
Laying out the framework... will fill in frequencies later I don't have on me from the FCC database and personal notes.
CSX Road and Dispatcher
|--Indianapolis Line Subdivision (Ex CR) (Post Road to Union City) - ID Dispatcher
|--160.800 Road
|--Indianapolis Terminal (Indy Terminal Sub. Louisville, Belt, Shelbyville, Crawfordsville, Frankfort, Zionsville, Petersburg, Hunter, Speedway, and Caven (ex CR) - IC Dispatcher
|--160.800 Road
|--St. Louis Line (ex CR) (Indianpolis to Terre Haute) - IB Dispatcher
|--160.230 Road
|-- Garrett Sub (ex B&O) (Willow Creek IN to Garrett) - RB Dispatcher
|--160.230 Road
|--160.290 Dispatcher
|-- Indianapolis Sub (ex B&O) (Indianapolis to Hamilton) - CF Dispatcher
|--160.230 Road
|--161.320 Dispatcher
|-- Indiana Sub (ex B&O) (Ohio Line to Washington) - CF Dispatcher
|--160.230 Road
|--xxx.xxx Dispatcher
|-- Illinois Sub (ex B&O) (Washington to Illinois Line) - CF Dispatcher
|--160.230 Road
|-- Garrett Sub (ex B&O) (Garrett to Ohio Line) - RB Dispatcher
|--160.230 Road
|--161.370 Dispatcher
|-- C&ED Sub (ex C&EI) (Danville IL to Howell Yard) - SB Dispatcher
|--160.370 Road
|--161.520 Dispatcher
|-- Hoosier Sub (ex L&N) (Ohio River to Bedford IN) - SB Dispatcher
|--xxx.xxx Road
|-- Monon Sub (ex L&N) (Lafayette to GTW Connection) - RA Dispatcher
|--160.370 Road
|--160.320 Dispatcher
|-- Lafayette Sub (ex L&N) (Lafaeytte to Cloverdale EOT) - SA Dispatcher
|--160.370 Road
|--160.590? Dispatcher
CSX Yards and Switching
|-- Avon Yard
|--xxx.xxx Hump
|--xxx.xxx Puller
|--xxx.xxx xxx.xxx Car Inspectors Repeater
|-- Indy Terminal, Hawethorne, Transfer Yard
|--xxx.xxx Belt 1
|--xxx.xxx Belt 2
|--xxx.xxx Belt 3
|--xxx.xxx Belt 4
|-- Garret Yard and Crew Change
|--xxx.xxx Yard Ops
|--xxx.xxx Switching
|-- Lafayette Yard and Crew Change
|--xxx.xxx Yard Ops
|--xxx.xxx Switching
|-- Howell Yard and Crew Change
|--xxx.xxx Yard Ops
|--xxx.xxx Switching
CSX Other
|-- MOW
|--160.130 Ex CR MOW
|--160.055 Ex CR MOW,Avon Hump Diagnostics.
|--160.785 Pre CR MOW
I basically want to make sure I remembered all the subdivisions yards and such.
AK9R
Super Moderator
Central Indiana
|--Indianapolis Terminal (ex CR) - IC Dispatcher
May want to expand on this to say that it includes the Crawfordsville and Frankfort Secondaries. Shelbyville, too.
|-- Garrett Sub (ex B&O) (Indianapolis to Garrett) - RB Dispatcher
Indianapolis to Garrett?
|-- C&ED Sub (ex C&EI) (Garrett to Ohio Line) - SB Dispatcher
Should be Danville IL to Evansville
|-- Lafayette Sub (ex L&N) (Lafaeytte to End of Track) - SA Dispatcher
Might want to say Lafayette to Cloverdale instead in case folks don't know where the track ends.
Looks good, Shawn. That's what I had in mind.
Bob... (aka CRBlue)
KC9JUM
Indianapolis, IN
cut and paste typos. I will fix them.
And for the record.... Amtrak's Beech Grove facilty is on
452.900/457.900 repeater
K9GTJ
Kokomo, IN
KC9JUM - when listening to your feed, I sure hear a lot of "odd" stuff. The railroad lingo is foreign to me. Thanks for providing it.
