Indiana State trunked systems
whitesox4life
Grant Co, IN
Does anybody have the talkgroups and fleetmaps for the state of indiana systems that run on the different county towers? for example, i need the fleetmap for the indiana, state of (madison county). i have talkgroups and freqs just no fleetmap.
KD4YGG
State Project Hoosier SAFE-T is a Type II system. No fleetmap necessary - it's the default for trunking scanners.
DaveIN
Founders Curmudgen
West Michigan
You need to program it as a type one (i) "E1", then change the fleet map to the preset :E1P2, Type 1, Preset 2.
Selecting a Preset Fleet Map
1. Set the scanner for conventional scanning and
press PROG then TRUNK to select the bank to
store the fleet map. A previously programmed
trunked frequency appears.
2. Press a number key to select the bank to store the
fleet map.
3. Repeatedly press V or W to select E1, then press
E.
4. Press DATA (ALT).
5. Repeatedly press V or W to select the name of the
desired map E1P2. The preprogrammed
fleet map appears.
6. Press E (SVC), then press SRC (LIMIT). The scanner
then searches for transmissions using the preset
map you chose.
whitesox4life
Grant Co, IN
i have done all of that but the talkgroups show up in a different form than what i have. one that is showing up constantly is 000-02. i can not switch it to a different view of that talkgroup. can anybody help me figure out how to do that or can email me a list of talkgroups in that form.
DaveIN
Founders Curmudgen
West Michigan
Yes, the talkgroups will display like that: Delaware County Talkgroups
Subfleet DEC HEX Mode Description
000-02 0 000 A Radio station WLBC FM 104.1
