Hi LaLa and readers,
Writing from experience, get the biggest, baddest "deep fringe" TV/FM antenna you can get your hands on and a healthy rotor, mount it as high as possible and you have it made when the sporadic E propagation or tropospheric ducting rolls in. The best transmission line I have found is 300 ohm foam dielectric twinlead, split it off to your TV (you'll probably need an adapter there) and do a bit of TV DXing while you're at it. Just keep the twinlead away from metal, it's not coax you can just run anywhere.
The thing to remember is wideband FM and TV are power hungry transmission modes unlike narrowband FM and others used for communications. More gain is needed at both ends for good signals and the directivity of a beam antenna is manditory to reduce interfrence from many signals coming in from several directions at once. Don't expect miricles in the latter department, I have sometimes found so much on the channel I couldn't hear or see a thing through the mess.
BTW, my best DX was a low power FM college station in Minnesota, A UHF TV station in Boston, channel 3 TV from Bogota Colombia and channel 4 from Honduras. I have the last on tape as clear as a local broadcaster, a show where the chief engineer was giving some kids a tour of the transmitting facility. Not bad from central NJ if I must say so myself. (;->)
Oh, check out cable channels 57 and 60 for Amateur 70cM TV while you're at it.
Helpful hint if you don't already know, switch the FM receiver to mono and tone controls to flat or a slight mid boost for clearer audio, reduced highs reduce hiss. Turn the color off on the TV, color snow makes detail impossible to see and you can miss the ID panel.
