W2IRT
Hi all,
I have two scanners at present, a BCD996xt and a 996p2. A couple of my local agencies are on conventional VHF and UHF repeaters and I'm using a tower-mounted discone at 40' for those, with good success on my 996xt.
Where I'm having difficulties is on the statewide 770 MHz phase-2 system on my 996P2. I don't want to spend the money on a combiner, and since the 996p2 is dedicated almost exclusively to that NJ statewide "NJICS" system, I need something that performs well in that frequency range. At the moment it's connected to SpectrumForce mag mount sitting on top of my power supply inside a one-story house, roughly 10' above the outside ground level. I'm finding the signal quality varies wildly on this antenna, from 1 "bar" to full. I've tried moving the antenna around on the supply, and moving the supply around on top of the desk, but I can't seem to keep a strong signal with this. Since this is a P25 Phase Two capable system, I'm finding that with weaker signal levels comes increasingly garbled transmissions, even with the latest firmware update on the 996p2.
So I'm wondering if there's something better out there that will give me some gain on 700 MHz and as a secondary concern, might still be somewhat usable on UHF/VHF-hi if I need both radios on the local analog system.
Conversely, would I run into any significant problems if I just split the discone signal between the 996xt and 996p2? Perhaps putting in a small preamp to compensate?
Thanks in advance.
Thanks in advance.
