Indoor antenna for my new Bearcat 996T
VonKarl
Baltimore, Md.
Can anyone suggest an All-Band antenna I can purchase that would attach to the BNC connector on the back of my radio? The Maryland State Police are on the 39Mhz. while Baltimore city is using 800Mhz (and soon to convert to 700Mhz. I was told).
Thank you in advance for any positive advice.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
That 700 mhz rumour is old as the hills. Forget it - the state simply hasn't got the money for it. Most barracks are now either getting 800 mhz radios (MSP Berlin barracks has them, for example) or working through a patch to have a talkgroup (or more than one in some cases) on their respective county's 800 system (Anne Arundel and Howard counties, for example - I hear both on a regular basis).
Apart from that, the 39 mhz system used by MSP is simplex only, so it's tough to hear, especially with an indoor antenna, unless you are reasonably close to the action. If you have an attic you can use, putting a ScanTenna or discone (or even one of those DPD antennas, if the attic is big enough) is going to help tremendously. If not, probably the best you can do is to get one of those wide band mag mounts and put it on something metallic, then get it as near to a window or outside wall as possible. You may need to move it around somewhat to find the sweet spot....73 Mike
don333
Baltimore County fire & police will getting a 700 Mhz system to be completed by 2011
VonKarl
Baltimore, Md.
Maryland's use of the 700Mhz. band
I thought the new band would be in place in a while but not as soon as 2011!
Well, at least the BCD996T will be able to use it when it is ready.
