Indoor GMRS antenna
DY2_TTY
Hi all,
I am looking for an indoor GMRS antenna that will work better than the one that comes with the Midland MXT105.
I have searched and could not find what I am looking for.
I saw Ed Fong's UHF antenna on ebay and I called him today to ask about it.
I am limited to having the antenna on the wall, and he said the antenna will not work and advised me the antenna needs to be a minimum of 5 feet away from the wall.
I can't put the antenna outside because I don't want to drill, and this set up is temporary anyway.
Any advice will be appreciated.
Thank you
jonwienke
More Info Coming Soon!
VA
Get a UHF mag mount antenna and stick it on top of your refrigerator.
amphibian
Canton, Texas 75103
Hi all,
Thank you[/Q
Take the antenna that is shipped with the radio, then go get you the "largest" cookie baking pan (sheet) you can find (generally a 3" x 3") from the kitchen cabinet or buy one, then place that antenna in the middle of the cookie sheet, then just place it were you want it. The cookie sheet acts as a ground plane for any mag mount antenna. You can paint the cookie sheet so that it looks good --- just be sure to tape up the area where the antenna will be in the middle with masking tape before you do -- so that the antenna will have a good ground when you are done....
Make sure the antenna stands straight up when done --- in other words don't do like a friend of mine did and screw the cookie sheet to the wall and then stuck the antenna to it.... doesn't work very well.......
cmdrwill
So Cali
I hope amphibian meant to post 3 feet, not inches. The ground plane needs to be a minimum of 1/4 wave length in all directions. So one would need a one foot by one foot cookie sheet for GMRS.
My boss at one of the MSS's had his UHF 1/4 Motorola NMO antenna on a mag mount on the refrigerator at home. So he could keep track of the 'night shift'.
I like the 1/4 wave NMO mag mount antenna mag mount upside down on a metal ceiling vent.
DY2_TTY
thanks all, I'm making a quarter wave ground plane instead, I'm just waiting for the parts.
amphibian
Canton, Texas 75103
Just as long as it is one of the largest of the cookie sheets in the kitchen or store...
The ones I generally us are 20" by 20" in size and with a thunderchicken meter it shows no reflected at 50 watts on GMRS channels... That is with a maxrad gain mag antenna...
DY2_TTY
I just made a quarter wave ground plane, just need to bend the radials, but not sure of the measurement. Is there a "best way" from where the bend needs to start, like the distance of the "bend" from the reflector?
aveighter
I was referred to a company that makes GMRS specific products, dpdproductions.com, for a mobile mag mount. I noticed they advertise indoor antennas that can be wall mounted.
I haven't done business with them yet so can render no opinion but it does look interesting. I plan to purchase the mag mount.
movinon
Oklahoma
I just bent mine down at 45 degreed. Works fine.
Sent from my SAMSUNG-SM-G935A using Tapatalk
cmdrwill
So Cali
Nice "groundplane" antenna.
6.05 to 6.4 inches on the 'elements'. And 45 degrees 'down-tilt' on the radials is good.
Delta33
Clinton Iowa
DO NOT use a Swr meter designed for CB ! ... Thunderchicken ?? As mentioned previously, a 12" square steel surface works well like a refrigerator or file cabinet.
DY2_TTY
It's now up... a lot better than the rubber ducky. It's about 3 feet away from the wall, and 3 feet from the ceiling.
cmdrwill
So Cali
Very nice... Paint the 'mast' the same color as the wall, and it will blend in.......
