Indoor high performance VHF/UHF aircraft antenna solution
iMONITOR
Silent Key
S.E. Michigan
For those of you who can't mount an antenna outside and want to monitor both VHF and UHF aircraft this is what I did and it was a total success!
Start Harvest D-103 Dual-Band VHF/UHF mobile antenna. (Mine is on a mag-mount on a steel 4-drawer file cabinet) feed into a Stridsberg FM Notch filter feeding into a Stridsberg PRE-20 Pre-amplificer, fed into a MC202 2-port passive (not active) multi-coupler, fed into two scanners of your choice. I opted for only a 2-port as I'm using this setup with two BCD996P2 scanners and I don't plan adding any more for this purpose in the future.
Stridsberg Engineering
Haarvest Aircraft Antenna
