INDY Metro area DMR
milf
Careful, I CAN hear you!
Indianapolis, IN
I am in the process of getting the local business and hospital DMR systems worked out. This is a bit of a challenge as some of the hospitals have the same freqs, such as Franciscan South, and IU Methodist with 451.8875.... Being that they have small coverage areas, I will need to make runs down to near Franciscan South to get its C, TGs, and Slots,.. And will have to travel around to closer to the campuses... SO please be patient with the slow progress.
milf
Indianapolis, IN
OKAY I can confirm the JW Marriott is DMR. WIll be adding all the freqs, and CC etc as I get them nailed down.
milf
Indianapolis, IN
OKAY guys and gals, I could use some help on this project. ANYONE that can do DMR please feel free to jump in on any of these:
ERS TRS
LOS/ICC TRS
Indianapolis International Airport TRS, both of the systems... The SMR 900 MHz is low power and ONLY covers the local airport area, the UHF one should give good signal all the way into downtown for the Heliport.
Most of the hotels, there is one that is NXDN, so I cant help on that one....
Simon Tower
Castleton SQ Mall
The Fashion Mall at the Crossing
The Hospitals, I am getting some of the stuff, but could always use any help.
ALSO Perry TWNSHP Schools is going to DMR
For the Conventional DMR, we need the Color Codes, Slots, and any TGs.
For the Trunked, Color Codes, TGs, SysID, Site ID, and LCNs. Oh and verification it is Connect Plus, Capacity Plus, Hytera XPT (or Other Tier III).
milf
Indianapolis, IN
Perry Township MSD LTR now DMR
Well, took a listen today, and the analog LTR TRS has been converted to MotoTRBO Capacity Plus. No license changes for this system as of yet. The Conventional systems licenses have been changed, but not the TRS... But anyway, need as much help as possible on this one too. Need SysID, Color Code is 13. Need LCNs. As it is only 4 freqs, once PTMSD is back in session shortly, should be busy enough to nail down. I will also take a listen to the PTMSD conventional repeaters in the near future.
N9BA
That one guy...
Central Indiana
DMR downtown
BCD436HP with DMR
Sent from my LG-K330 using Tapatalk
Sounds like I need to education myself on using my 436 to gather information about the downtown systems. Are you just using the discovery functionality?
milf
Indianapolis, IN
No. Programming the systems in as recommended in conventional until I get hits the scanner confirms as to type. Then setting up systems for proper scan after that.
I used the color code and ID search at the airport last week to read a potential client's color code and talkgroup.
I wish the CC and TG display was the same size as the site and system name
