Info: Medicine Hat City Police (help)
k0ke
Hi, I am new to this forum. I have done alot of reading and am enjoying it. I use a BC898T and a recetly aquired BCD 996T. About 2 years ago Medicine Hat City Police voulentarily changed to the ACPO 25 system. Not sure if it's encrypted. Their fequency is 866.5500 . I cannot seem to find any info on their system anywhere I have looked. All I get is a high pitch squeal when they transmit. Tried tweaking the scanner, can't get any voice. I was hopping their would be some type of comm. map table somewhere or something to set me in the right direction. I would appreciate any advice or info .... thanks in adavce.
avgas
Alberta
I dont know too much about the scanner you have but the info in the data base is correct for all 3 channels the police dept use. Channel 3 is encrypted but not all of the time. I have a pro96 and can hear them just fine. I am guessing you need to change a setting and you will be up and running.
Check out page 52. Not sure if you tried this or not.
http://www.uniden.com/pdf/BCD996Tom.pdf
k0ke
update
ok, what I did is saw a 067.0 show up in the log, I entered it into the "tone" and now I have good clear audio. The p25 indicator show up. My next stepwill be to search the system to get a fleet map. Thanks Tom. You in the same area?
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
You have a 67.0 tone and P25? I'm not so sure that is supposed to be able to happen.
I don't spend any time in the Hat myself (I'm west of Calgary) but I might be convinced to do a road trip someday once/if the snow clears, i.e. month or two.
I think Unitrunker displays NACs on P25 conventional channels.. it would be interesting to see if it shows anything besides the default '293' for MHPD.
k0ke
Medicine Hat on true APCO-25?
no matter what I do, can only receive MHCP in conventional mode. If I try MOT1 or MOT2, or any other, cannot get them. Their on digital, but appears not to be the full blown APCO-25
k0ke
avgas, are you set up in CONV/ MOT1/MOT2/EDC/EDS or LTR? sorry, looked at the wrong post , got names mixed up
DX-300
Alberta, Canada
My investigations in the past have shown me their using only individual non-trunked channels down there. I'm not sure about the difficuly your having with hearing voice though, as when I went there I had success with both my BC785D then later with my 396T as well.
Jay911
If there's no steady control channel noise, they won't be trunked. "true" P25 doesn't need trunking; it just has to be of that particular digital flavor of audio, IIRC.
If one or more of you down that way have any tapped radios, it would be a major coup to let Unitrunker have a couple passes and see what it can pick up.
To elaborate: A single P25 "conventional" channel can actually have multiple "talkgroups" depending on what NAC is used. NAC stands for Network Access Code and is essentially the digital version of a CTCSS/DCS code. I believe (but I'm not 100% certain) that Unitrunker can decode NACs on conventional channels.
I just realized I have a fairly easy way to find out, though. ;) I'll explain more later if it's needed.
k0ke
I was able to clean up the sound issue a bit by doing what avgas reccommended (thanks by the way) No wall I have to do is figure out what to do with my BC898T.
avgas
Alberta
They are not trunked. Putting in the single freq. works fine for me. As for the 898, I have a bunch of non digital scanners that I just keep around to monitor everything else. I mainly monitor the city police and fire on the digital scanner. I have so many non digtal units that I have spent money on I cant get rid of them.
What do you monitor KOke?
k0ke
got it figured out, then the display on the scanner went all bad, sent it back. was working good for p25 (city police) thinking of getting a GRE, what do you think about them?
avgas
Alberta
I cant help you there. I have a pro-96. This is my first digital scanner. I didnt have much luck when I bought it. I ended up exchanging it several times. The first radio had no display, the second had no audio and so far the 3rd one is working good. I made several trips to Havre to exchange it. Where have you been buying your scanners?
