Info Ras Motorola
iu4jic
I need to add 10 receive-only radios to a Motorola DMR repeater bridge that uses Enhanced Privacy and RAS (I don't need to transmit, just listen). I know the Enhanced key, but we don't have the RAS code. By configuring the Motorola or Hytera radios that support ARC4 E.P., can I listen without setting up RAS, or will I not receive any signals? Thanks to anyone who can help me.
iu4jic
Since I can decode the signal with SDR and DSD FME, I expected to be able to do it with a radio too
iu4jic
It's much better to capture the audio with Windows and publish it so that it can be listened to with a smartphone on a dedicated site.;)
Echo4Thirty
Colorado Springs, CO
This is an incorrect expectation. Software can be instructed to compensate for the extra RAS frames, radios will not ignore it. In other words, the radio is working as it was designed. No RAS, no listen.
KE4ZNR
Radio Geek
That part, why it's called Restricted Access to System, meaning UNAUTHORIZED subscribers cannot ACCESS (receive or transmit) the RAS enabled system!
iu4jic
Ok, thanks for the replies, now it's clearer to me. Having tried a friend's Baofeng, which allowed me to listen to the audio (obviously distorted by the Enhanced Privacy feature), I thought it was possible to insert the key into any Motorola or Hytera radio, but I realized it wouldn't work.
