Hello from Northwestern Ontario Canada, I am hoping someone here can help me with a Yagi Antenna Array. I have used K7MEM’s calculator for the individual antennas being 23 element @ 1440mhz with an estimated 15.9db gain and 24 degree beam width.
These antennae will be utilized for radio astronomy in a 3 x 3 antenna array pattern omitting the centre antenna only because I can not locate any information on how to phase 9 antennas together with coax. My thoughts are that a square shape pattern would provide a more circular beam and for me more mechanically adaptable vs a rectangular shape. Like wind load leverage.
All I have been able to find is multiples of 2 or 4 for joining antennas together. So at this point I only have information to connect 8 antennas unless someone can help with adding #9 which would be super great because I have material for 9. I do not want to get into expensive off the shelf antenna combiners.
I am also looking for information of beam width and gain for stacking multiple antennas together. There is much information on putting 2 yagi’s together but nothing beyond that unless you have a major in electrical engineering to decipher the formulas. I am just looking for a rule of thumb based on my antenna mentioned above and the number of antenna I want to put into the array.
Information I have found on stacking two yagi antennas together loosely claim 2x db gain (3db) and 1/2 the beam width. But beyond stacking 2 together I have found nothing.
I need the estimated beam width so I can input the data into a radio astronomy program I am running so that it can show a real-time observation (receiving) with the Meridian Drift Scan Table. Once inputted the beam pattern is projected onto the realtime display.
These antenna are of cross polarization design with 2 coax coming from the array to the receiver so left circular, right circular, horizontal or vertical polarization can be achieved.
Thank you,
Bob
Thank you,
Bob
