Infuriating Interference
KM4BLG
Hi all,
I've been having an issue that is about to send me over the deep end.
I am having light interference on the VHF high band. I have noticed it at certain parts of the 2m ham band and the local fire frequencies (150ish range). It is a dead carrier too strong to squelch out, and weak enough that moving misc objects around makes it go away (for a while).
I have tracked it back to my wireless router. I have tried half a dozen router models, brands, and power supplies, but it doesn't help. It is certainly the router though, because when I unplug the router, it goes away completely.
Of course, the best solution here is to just move the scanner and router away from each other, but due to living in a very small place, that just isn't feasible.
Any ideas?
Hi all,
Any ideas?
Cable TV modem, DSL or something else? There are some carriers on cable TV systems that can fall in those ranges. My VHF mobile will break squelch at my inlaws house due to some bad connections on one of the neighbors cable TV drops.
Groeteschele
Munich
Hi all,
Any ideas?
Hello. Another thread address problem like this. All my radios are in my flat, all aerials outside of flat on roof and outside of windows using high quality double shielded and grounded coaxial cables. All ancillary computer equipment, power supplies and such are in closet. All SDR sticks are incapsulated at base of some aerials outside windows. and usb cables run to computers and laptops. Very little ambient noise from sources outside flat. I hope this helped.
a417
<snip>
Any ideas?
Is it a router that has removable antenna? If it is, put the router inside a makeshift faraday shielded box and just route some extension wires out of the shielded box for the antenna. The only signals that should come out then would be the purposeful ones from the antenna.
chief21
Summer - Western NC; Winter - Tampa Bay FL
It might not actually be the router itself. Remember that when you remove power from the router, it also removes the ethernet signals from all devices downstream of the router. If you have any such devices (switch, hub, printer, external drive, PC, etc.), check them for noise sources as well.
KM4BLG
Thanks all. It does have removable antennas. Might try that. Running on Fixed Wireless here, so standard ethernet jack on the WAN side. Runs to a Ubiquiti radio outside. Unfortunately can't go totally wired. Too many phones and tablets.
