Ingham Co. EDACS
rdale
Lansing, MI
03-101 is the new countywide EVENT 1. I think I heard there were 15 of them coming, they were used operationally for the hospital exercise a week or two ago. 02-101 is just for testing the new Tower 2.
rdale
Lansing, MI
Not sure of the name, but yes, all radios either have those new event channels or will soon...
MilbourM
Williamston MI
256 & 257
I heard some testing on this set of talkgroups on monday october first for about 3 hours thay would count up to seven abou 200 times and move to the other channle what is that about and do you think that theas talkgroups fall in to the sheriffs talkgroups area of the Ingham county EDACS
rdale
Lansing, MI
mattmil13 - as mentioned above they were testing the tower 002. That tower was added to provide better coverage for units operating in that area, it will only have a subset of talkgroups (that's why it has less frequencies.) Don't program it in your scanner.
MilbourM
Williamston MI
Tg 751
I do not see id 751 in the database and just worndering what it is used for i heard Meridan Fire dispach on that TG today just worndering if it is a pach or something like that
thanks
Matt
___________________
BCD396T
PRO-97
PRO-83
Motorola SP-50
wcs12140@wmston.k12.mi.us
rdale
Lansing, MI
Highly suggest using the AFS format as it makes things easier to decode on the fly. That is the simulcast that triggers for a dispatch, if you only want to hear them you can lock out the main Meridian FD talkgroup and you'll only hear dispatches.
MilbourM
Williamston MI
thanks alot
for AFS Format what is the difrence between the AFS and the DEC Modes Besides the - in the middle as in how do you read the AFS format is it anything like the LTR systems TG IDs.
Matt
______________
BCD396T
PRO-97
PRO-83
Motorola SP-50
rdale
Lansing, MI
You can see in the list on the database here, most 02's are police, 03's mutual aid, 04's fire, 05's dispatch, 08's Clinton Co, etc. Not an exact relation, but close.
rdale
Lansing, MI
Many, hit lockout when you hear a toneout of interest on the dispatch channel and if it shows up with a 05- then you have the ticket.
rdale
Lansing, MI
Not offhand, when you hear a dispatch on FIRE MAIN then press LOCKOUT and see if another talkgroup comes up. If so - yes. If not - no. Then unlock FIRE MAIN.
scannerman5000
Eaton Rapids, Michigan
05-105 is a simulcast on Fire Main.
some out-county fire departments use plectrons or whatever you call them, and dispatch uses the patch to activate them.
I dont know why departments dont just buy new UHF plectrons and use fire main's conventional frequency (460.600) for dispatch.
