Ingham Co. EDACS
RayAir
Testing on new TG today 02-001 unknown what it is used for.
Can your Jaguar radio receive AEGIS or Pro Voice signals? Around me Livonia police use an analog EDACS system, but the surveillance and detectives channels only are using AEGIS voice. That seems kind of risky to me. Correct me if I am wrong, but if I bought a EDACS radio capable of AEGIS and programmed the freq's in I would be able to hear the detectives channel? I do however know that technique to listen in won't work on M/A-Com Open Sky though, something to do with the radio needing an I.P address to access the radio network. Oakland County was supposed to be up and running on Open Sky back in 2004 or earlier and only a select few cities are using it now (July 2008).
rdale
Lansing, MI
I'm not sure if detectives are digital or encrypted... I know some are definitely encrypted, but once it gets digital most of us don't care ;) I'm not sure you can just program an EDACS radio for trunk tracking in the first place?
RayAir
On some nights I can receive Ingham Co. EDACS from central Oakland County with a indoor scanner antenna on the second floor (Watson Super Gainer).
RayAir
I can sometimes listen to this TRS from central Oakland County with an indoor antenna.
rdale
Lansing, MI
I think the transmit tower is a little higher up, and more powerful than your handheld though :)
N8RUS
S. E. Ingham County MI
Rob, We have a receive tower located in Stockbridge and the signal is sent via microwave to Lansing. Oh well, we'll keep trying............"Fire Center from 1002", Fire Center from 1002"........helloooooo?
rdale
Lansing, MI
Toneouts I've found:
Lansing Twp Sta 51 - 928.1/368.5
Lansing Twp Sta 52 - 928.1/389.0
Lansing Twp Chiefs - 928.1/410.8
Leslie Fire - 832.5/368.5
Delhi Twp Fire - 600.9/368.5
Leroy Fire - 634.5/368.5
techsender
N of St Paul MN
I am visiting Lansing in a couple of weeks and have programmed up my Pro 97 for the EDACS stuff. I have not yet used this scanner for EDACS, LTR has not been a problem. Anyone have tips I should look for before getting there and finding out I programed something wrong ? LTR was very straight forward.
techsender
N of St Paul MN
Trip went great, programming I had done in advance also worked well. I was pleasantly surprised. They have their coverage area worked out well it seems, two counties over and not a peep, one county over and reception was great.
rdale
Lansing, MI
I'll be setting up some FTO decoding the next few days - if there's a particular department anyone is looking for, PM me...
rdale
Lansing, MI
Latest list of radio ID's:
Sheriff LEIN Private 105 0
LPD-N Dispatcher Private 108 0
LPD-S Dispatcher Private 109 0
Shrf Dispatcher Private 110 0
Fire Dispatcher Private 112 0
LFD Dispatcher Private 113 0
Meridian Disp Private 121 0
EL Dispatcher Private 123 0
Patch Radio Private 152 0
Med211 Delhi Twp Private 654 0
Med212 Delhi Twp Private 658 0
Eng11 E Lansing Private 860 0
Shrf Command Pod Private 1414 0
333 Dansville Private 1650 0
Resc337 Dansvlle Private 1656 0
Engine 41 Private 1870 0
Truck 41 Private 1872 0
Medic 411 Private 1874 0
Battalion 49 Private 1880 0
Medic 41 Private 1882 0
Medic 46 Private 1884 0
Engine 42 Private 1900 0
Engine 43 Private 1908 0
Battalion 41 Private 1911 0
Truck 44 Private 1916 0
Engine 44 Private 1918 0
Medic 46 Private 1920 0
Engine 45 Private 1930 0
Medic 49 Private 1932 0
Truck 46 Private 1938 0
Truck 49 Private 1940 0
Engine 46 Private 1942 0
Medic 41 Portabl Private 1943 0
Engine 47 Private 1952 0
Engine 48 Private 1960 0
Truck 48 Private 1962 0
Squad 46 Private 1986 0
Engine 42 Private 1987 0
Engine 49 Private 1994 0
Engine 45 Private 1996 0
Engine 44 Private 1998 0
Battalion 41 Private 2006 0
Medic 49 Portabl Private 2043 0
Medic 49 Private 2045 0
Medic 49 Private 2056 0
Engine 47 Portab Private 2117 0
Engine 48 Portab Private 2137 0
Engine 48 Portab Private 2187 0
E511 LansingTwp Private 2974 0
Med51 LansingTwp Private 2978 0
Med511LansingTwp Private 2980 0
Med52 LansingTwp Private 2988 0
Med52PLansingTwp Private 3005 0
Med51PLansingTwp Private 3015 0
Leroy Chief 601P Private 3181 0
Leroy 618 Private 3182 0
Tank1105 Willmst Private 3188 0
Med171 Leslie Private 3292 0
3502 Mason FD Private 3502 0
3545PMason FD Private 3545 0
920 Meridian Twp Private 3717 0
Med1114 Willmstn Private 4592 0
Med1115 Willmstn Private 4594 0
A220 Stockbridge Private 4802 0
E1041 Stockbrdge Private 4890 0
E1051 Stockbrdge Private 4894 0
E1081 Stockbrdge Private 4906 0
E1101 Williamstn Private 5060 0
E1102 Williamstn Private 5062 0
E1103PWilliamstn Private 5065 0
Tnk1105PWillamst Private 5067 0
WilliamstnPChief Private 5083 0
BC91 MeridianTwp Private 6710 0
jdc50
lansing michigan
What happening with Easton County
Has any heard what is happening to Easton County as far as their radio system? I was wondering if the plan to use a system simular to Ingham county.
