OP25 Inovato Quadra running OP25
ewh01
vineland, nj
FYI - I have Boatbod's OP25 running on a quadra. sounds great, maybe even better than on the RPi.
It was going to sleep, suspend, whatever it is, so I added the command to stay "awake", but that is not a Quadra issue. Let's see how it goes long term.
DC31
Massachusetts
Likewise, I have SDR-Trunk running on a Quadra. It uses a lot of CPU and Memory but has been stable for the last day or so. Streaming the audio out to icecast using pulseaudio and darkice.
VexingRaven
Any details on how many streams you're decoding at once or how much spectrum you're covering? I'd figure P25 following would be pretty tough on a cheap SBC like that, but quite promising that it works since that's probably a good way to get a cheap, low-power 24/7 scanner going.
DC31
Massachusetts
I have kept it pretty limited to start. I am streaming 3-4 talkgroups, none of which are particularly busy. As far as spectrum width, you are going to need to help me with that. Where do I find that info in SDRTrunk?
VexingRaven
How many channels are in use at once and how wide is the bandwidth of your SDR (or which SDR do you have)? I'm even more curious now that I see you're using SDRTrunk, the prevailing wisdom in the SDRTtrunk community is that there's no way SDRTrunk will run on an SBC because it's too CPU-intensive, so hearing that you got that working is awesome. I'm a bit too attached to Trunking Recorder myself to go to Linux, though.
