Input Audio
slingshot202
New Jersey
Anyone know how to adjust the input audio to a feed? I am using a BCT-346XT for one of my feeds and while the scanner is set to volume of 1 it still screams out of Broadcastify.
Looking for any advice on how to regulate it a little better. I have the volume on the web almost zero'd out and it still over powers the other feeds I am listening too.
Thanks.
Eng3ineer
Southwest Arkansas
Check the mic levels in the computers sound area.
Control panel, Hardware, sound, recording, select mic input your using for the feed, levels.
I run my radio/scanner at about half volume then adjust the computer levels. Also if use Proscan RadioFeed it allows you to adjust the volume levels as well.
Hope this helps...
slingshot202
New Jersey
Eng3ineer,
Was camping this weekend, however, I was able to look into this and you fixed or helped me adjust the input volume.
Thanks a million.
CJ
