INPUT FREQUENCY QUESTION
scannerman200
North Central Alabama
the main police frequency that I monitor is 156.210. The input or backside of that frequency is 158.940. Could the police talk on the backside frequency (158.940) without being heard on the receive frequency?
Colin9690
County 21
APE282018
Well if they talk on the input, you won't be able to hear that particular unit unless you're close to the transmitting radio. What I think you're talking about is something called talkaround. It allows unit-unit comms without bypassing the repeater.
Hope This Helps
mdulrich
Van Wert, Ohio
Yes, they could talk on the input frequency of the repeater without being heard on the repeater by using a different (or no) PL.
Mike
N
N_Jay
Guest
Mike
But the run the risk of blocking the repeater.
That is why talkaround (simplex) is on the OUTPUT frequency.
Some very rural areas scan the input so they can hear a nearby unit if they are not within range of the repeater.
edweirdFL
Daytona Beach, FL
Due to the repeater blocking issue, I've never seen a talk around on an input freq. On the output, or a third freq yes. (VHF or UHF)
Ed
toydriver_det
Madison Heights
Ed
I have to agree here. Our company radios have talk around but all it is on chan 2 you transmit on the repeater output freq with the same PL. If you are close you can bypass the repeater but still hear anyone calling you through the repeater.
mdulrich
Van Wert, Ohio
I agree, I have never seen simplex use on the input side, but there was another thread where some people swore systems in their area used the input for simplex operations. I don't see the wisdom in doing this at all and I think there is the potential for real problems.
I was just answering the question, if it was possible to talk on the input and not be heard on the output.
Mike
N
N_Jay
Guest
Mike
What people may consider "Talkaround" may just the use of a second receive frequency set for th erepeaterr input.
This si common in very rural areas so closeby units will hear a unit calling for help.
