Input/Output
GottIstGutig
I know with UHF the input is 5 MHz higher than the repeater output, but how does it work for all the other bands?
DaveH
Ottawa, Ont.
If you are speaking of the U.S., +5MHz is standard for 450-470, but +3MHz in the 470-512 band. In the 851-866 band, separation is -45MHz, but in the 900MHz band it is -39MHz. In the VHF bands there is no standard separation possible, except the old mobile phones used +5.26MHz; and the marine band.
In Canada, UHF separation can be 5.000, 4.9875, or 5.0125MHz. In the 420-430MHz band, I believe +4.000 is used also.
Dave
N
N_Jay
Guest
800 MHz is 45 MHz (Base TX High)
900 MHz is 39 MHx (Base TX High)
470-512 is 3 MHz (Base TX Low?)
VHF is mixed all over the place.
Voyager
Dave
There are also standards in most ham bands.
29 MHz (10M) is -100 kHz.
50 MHz (6M) has no standard - common offsets are -500 kHz, -1 MHz, -1.6 MHz, and -1.7 MHz
144-146 MHz (2M) is +/- 600 kHz with a little + 1MHz in the mid-146 MHz range,
220 MHz (1.25 M) is all -1.6 MHz
440 MHz (70 CM), like 460 MHz, is all +5 MHz, but some areas do use some -5 MHz offsets between 445 and 450 MHz.
In the commercial bands below 200 MHz, there are no standards.
Joe M.
