Installing SRX-4 Dual Receive Board in VX-P924 - HELP
K2JAD
I have 2 UHF VX-P924 radios. I am trying to swap an SRX-4 VHF board from one and install it in the other. Does the radio casing have to be removed and how?
Where is the SRX-4 found? Thanks in advance.
cmjonesinc
I haven't ever touched a p924, but on most of the other Vertexs I've dealt with you just pop the battery out and the option board goes in behind it. There's typically a thin plastic cover that's just held on with adhesive. You'll have to read the radio with the programming software and enable the specific option board you're using. Here's some pics of a 417 I had laying in a junk box.
K2JAD
On these radios the board beneath the battery as you describe is apparently the P25 board.
cmjonesinc
Does the vhf radio you're taking the option board out of have P25? I ask because I wonder if it's either you can have P25 or the receive option.
K2JAD
Yes both radios have the P25 board and function properly on P25.
carlos7801
Lawrence MA
The Sub Band receive Board is located inside of the radio if I’m not mistaken underneath the main board. It’s screwed down to the rear portion of the chassis and requires you to undo the flex connectors to the display board and furthermore disassembly of the Bain board from the metal casing. The rear option board like everyone else is describing only holds the VSCM Board for both p25 capabilities and ANY encryption algos if flashed from factory with the proper matching FW and DSP.
