Intelligent Priority Scan
Bethanylt241
Bethany WV
How do I go about obtaining the Intelligent Scan Feature for my APX6500? I do not see it as a flash feature and not sure how to get it.
K2NEC
NA
What FW is your radio on
chrismol1
P25 TruCking!
Did you get it? I thought it was introduced in firmware R17 so you should see it under Scan, Scan Type the drop down menu - Intelligent Priority
GTR8000
NY/NJ Database Guy
BEE00
Not enough info provided to answer. Is this a 6500 AN or BN? What is the FLASHcode of the radio, specifically does it have trunking or is it conventional only? Are you working off of an old codeplug that was created before FW R17?
The codeplug needs to be aware of the radio's firmware version before you will see newer features. Program the radio with your codeplug, then read the radio back and work off of that codeplug which will now match the radio's firmware.
MTS2000des
5B2_BEE00 Czar
IPS works fine on every 6500 AN in our fleet, over 500 of them. No special flash other than P25 trunking/TDMA in the radios. If the scan type is set to Intelligent Priority, then it should work provided the firmware isn't ancient and codeplug version matches.
