Intellirepeater???
KD4YGG
Can anyone give a detailed explanation of the term Intellirepeater?
I keep seeing this in reference to some of the newer Motorola systems.
What are they?
How do they operate?
How should one program these sites in regards to trunking scanners?
Thanks in advance!!!
INDY72
Indianapolis, IN
Intellipeaters or intellirepeaters are the Motorola "smart" repeaters in use in most trunking systems,.. you program them into a scanner just as you would any repeater system.... They do not effect scanner usage,.. the functions are more important to an actual Motorola Radio. For a more indepth description keep watching the thread... N-Jay or nmfire, or Voyager will pull out the full page tech sheet for ya soon.. :)
INDY72
Indianapolis, IN
Also you might hear the term digipeater,.. which is the digital version of the intellipeater and is used on digital capable systems.
loumaag
Silent Key - Aug 2014
Katy, TX
Taken from Motorola literature:
An IntelliRepeater is a trunked repeater with built-in capabilities to perform the trunking functions without the need for a site controller. Any IntelliRepeater at a site can provide this capability if a station was to fail. This eliminates the need for central controllers at every site, while still providing full system capabilities.
WayneH
Forums Veteran
Super Moderator
Your master site
Please do a search. It's been discussed many times as I've gone over it.
"Digipeater" isn't a common term in the LMR industry [See below]. APCO-25 digital is an orderable option for the Quantar just as IntelliRepeater operation is.
-Wayne
loumaag
Katy, TX
wayne_h said:
"Digipeater" is a slang term. No such thing in reality. APCO-25 digital is an orderable option for the Quantar just as IntelliRepeater operation is.
Whereas this is true when talking about commercial and Pub Safety level systems, the term is a recognized one in the ham community in a very narrow sense. In the ham community it is a record and retransmit station set up for the expressed purpose to pass on AX.25 packets for both APRS and PacketRadio. It may also be interconnected to an ISP to post that information to other "digipeaters" for wider dissemination of the information passed locally. It is not correctly used in connection with any mobile relay duplex operation.
