Intercanyon Fire crossover from 45.08 to VHF June 19th
jimmnn
Colorado
Inter-Canyon 1 158.9250 MHZ 151.4300 MHZ 203.5
Hz Narrow Inter-Canyon Khuester Tower-Repeater
Inter-Canyon 2 159.0450 MHZ 154.8075 MHZ 203.5
Hz Narrow Inter-Canyon High Peak Tower-Repeater
Inter-Canyon Tactical 159.3075 MHZ 155.8575 MHZ 203.5
Inter-Canyon Simplex 151.4300 MHZ PL
Off Narrow Inter-Canyon Car to Car 1
Inter-Canyon Simplex 154.8075 MHZ PL
Off Narrow Inter-Canyon Car to Car 2
They are in negoiations with Indian Hills to use same frequencies and add the IH repeater to the above, DTRS use is only 6 portables for both depts so it is limited use on FIRE-SW.
Jim<
jimmnn
Colorado
MikeyB said:
So they're not on DTRS?
Nope and never have been that applies to most of those foothills depts Elk Creek, InterCanyon, Indian Hills, North Fork, etc.
800Mhz digital radios are just too expensive to equipt all the volunteers with.
Jim<
evilklown
Colorado
i am still get the hang of the scanning so if i wanted to listen to them frequncy's, i couldnt listen with my dgital scanner the pro-96 or can i? if not what scanner lets you listen to non 800 mhz. thanks.
jimmnn
Colorado
You certainly could monitor those with your Pro-96 but might be a little far away for the simplex ones.
Jim<
Evergreen, CO
Foothills Fire Departments
As stated before, the concern of the departments in the foothills has been the tendancy to go "digital" in critical situations on the state system. Bring your chair to Evergeen Lake, take in the view, don't forget your radio, and tell me I'm wrong.
greenthumb
Colorado DB Administrator
cstockmyer said:
Any chance these maybe added to the database?
I'll get 'em in, but i'm not familiar where a lot of these small volunteer fire agencies are - what county do these need to go in?
evilklown
Colorado
Jim<
is it the same as programing the digital.. were you need control channels to use the frequncy or is it set up differnt? i was going to also ask you what you ment by that it might be a little far away for the simplex ones? is it better to set up another scanner for the non digital so you dont start getting confused with digital and non digital on one. can you mabey give me away how you personally have it set up for easy and non confusing way.
jimmnn
Colorado
OK deep breath. Simplex channels don't utilize a repeater so are often much shorter in coverage distance, there are primarily used for on-scene operations such as fire ground channels.
Assuming you use win96 to program your Pro-96 you will see on the screen that programming a conventional channel versus a trunked one is completely different. No control channel is needed for the conventional ones just the channel itself and possibly the pl as well.
Digital and non digital can be mixed on one radio or seperated on different radios that's mainly personal preference.
I always recommend Phil's convenential and trunked files p96 files available at www.radiohacker.com they are an excellent source of beginning programming information or to provide you with a basic programming template to start with.
Jim<
MikeyB
Centennial, Colorado
Jim<
That is very true about the radios, but I thought some had put the digital radios only on the trucks, so you would hear the volunteers on VHF and the units on DTRS.
Anyways, for a breakdown on Jeffco, whick of the volunteer agencies are on DTRS?
Foothills, Highland Rescue, Pleasant View, Edgewater I hear on DTRS. What about Golden Gate?
evilklown
Colorado
Jim<
Thanks Jim i understand now.
greenthumb
These frequencies have been worked in to Jefferson County.
Out of curiosity, how big of an agency (personnel, district) is this? I'm curious because they have three repeaters and two simplex channels and that seems like a lot for a volunteer agency.
jimmnn
Colorado
Just a small 200 call per/year volunteer fire dept. But they might share them with another even smaller volunteer 100 call per/year dept.
Jim<
Evergreen, CO
Jim<
Deep breath done. There are several rural fire departments serving a given geographic area in the foothills west and both north and south of Denver. Foothills Fire is in Genessee, Inter-Canyon is along South Turkey Creek, and beyond, . These folks have been VHF, and I still hear them as such, but have confirmed transition to digital, at leasst in the case of Inter-Canyon, others likely to follow. They are very active. Worth listening to if the sites reach your area.
jimmnn
Colorado
Might want to check your sources, why would Inter-Canyon and Indian Hills invest in four new VHF's freqs if they are moving to DTRS? DTRS will remain in the mobiles but the overall operation for both of those depts will remain on VHF, each member will not be issued a $4,000 portable.
Jim<
