For Public Safety you can monitor the following: Sevier County Fire Paging is 464.225 with a PL of 136.5, Sevier County EMS Paging is 462.950 with a PL of 127.3, Gatlinburg Fire & EMS Paging is 453.850 with a PL of 100.0, Seymour Fire Department with a PL of 103.5, and Sevier County Dispatch Interagency is on 460.500 with a PL of 100.0. Seymour operates in Sevier/Knox/ Blount so you will hear other dispatch centers other than Sevier County Central. All other Public Safety is digital in Sevier County. Most Sevier County is on a Nexedge digital system and encrypted. Pigeon Forge Police use TACN and is in the clear on most channels. GSMNP is also on VHF & p25 digital with a mix of clear transmission and encrypted transmissions. Also bordering Sevier County are Knox, Cocke, Jefferson, and Blount. For Cocke County, you can monitor the following: Cocke County Fire on 460.575 with a PL of 127.3, EMS on 463.025 with a PL of 82.5, Newport Police on 460.200 with a PL of 103.5, and Newport Fire on 453.100 with a PL of 203.5. Cocke County Sheriff is on Nexedge digital and in the Clear. For Blount: Townsend Fire is on 453.075 with a PL of 94.8, Blount Fire is on 453.100 with a PL of 127.3, and Blount AMR & Rescue Squad operates on 154.355 with a DPL of 532. Townsend Fire and Blount AMR also respond into GSMNP for some calls for service. Everything else in Blount is on TACN with mixed encryption use. The only thing public safety-wise in Jefferson is 460.600 with a PL of 167.9, mainly used as the fire paging channel. A couple of other departments are on NXDN in the clear and the rest are on NXDN & encrypted. Most of Knox County's public safety you will not be able to monitor from that area. Plenty of businesses to listen to on interiant & FRS frequencies and other channels in the database. Some are digital but the majority are analog.
