chris451rr
I just got another TRX-1 mainly to use with DMR and NXDN, my other older TRX-1 has not been working on P25 LSM just every other kind of LSM DMR and NXDN>
The New TRX-1 (factory refurbished) is trunking and receiving the LSM just fine.
So, I did the following to the old TRX-1.
Reloaded CPU and DSP firmware with the app.
Swapped memory cards to the older TRX-1.
Still does not trunk the LSM so its a hardware issue not a setting issue.
Searched for the local oscillator so I could compare reference frequency and offsets.
Using a signal generator and the on the air control channel for Cedar Rapids, I did some narrow sweeps to find the local oscillator.
For example tune the scanner to sweep from 775 to 775.2 and observer the LO steps every 75khz between
394.2 394.275 394.35. It can also be seen at 2x and 3x of that frequency.
Next step was to set both the 'good scanner' and the 'bad scanner' to the same frequency so the LO can be compared.
Using a signal generator on the older TRX-1 in the 800 band it was 2khz low. The new Trx1 was not having trouble with LSM but the older
one was. My observation is that signals appear 2khz low on the older TRX-1. The LO is 2khz too high in the 800 bands.
Local oscillator frequency is critical in LSM systems.
Local ocillator reference drifted higher to the point where it will no longer trunk LSM but still trunks any of the other modes ; regular P25 and DMR/NXDN on any band.
My proposed fix is to re-calibrate the oscillator in the older TRX-1 so it is 2khz higher, then give it a try on the LSM system.
The new TRX-1 is trunking LSM just fine in P25-LSM mode. The old one is failing to show the T symbol in the display when the good one does,
but the signal bars are the same.
Conclusion if your TRX-1 used to trunk LSM but does no more particularly on 850mhz band, it has probably drifted off frequency enough to keep it from decoding the LSM types of trunk signal. Both scanners still exhibit the signal chop found in LSM systems but typically adjusting the position of the scanner will fix that(can be weather dependent)
Waiting to hear back from Whistler to see if they will tell me how to adjust this or if they want me to send it back.
They provide no technical information on this scanner at this point.
Chris 8/3/2019
Chris 8/3/2019
